Opinions: 5.1?....Or Beyond?
Discussion in 'Archived Threads 2001-2004' started by Valerie Brown, Oct 9, 2002.
  1. Valerie Brown
    Valerie Brown Stunt Coordinator
    Jan 5, 1999
    50
    I have 1 pair each of the JBL Northridge series N38s/N28s and an N-Center.
    I am happy with the above speakers and was thinking of
    buying an NSP1 (while they're still around) and using the 1
    pair of the N24s for additional surrounds and the N-Center as a rear center-channel. (The other pair of N24s would go
    to a Denon/Mission/Klipsch mini-system.)
    I could also go with 2 pairs of N24s, as additional surrounds. This would possibly save a little money, but
    for an additional maybe $20 to $30, I could go with
    the previous scenario and add some speakers to my mini-system.
    I am thinking about getting a Denon AVR-3803 or comparable unit (also like Pioneer's Elite line). I want something that would be well balanced for music/theater.
    Presently using a 13 year old Denon integrated amp...that refuses to die! Thankfully, it sounds nice. The N38s and
    N28s sound nice, together. Better than they do apart! The
    N28s seem to add a more bass to the mix? (I would assume
    because it's the same size woofer as the N38, but a smaller
    enclosure?)
    Well, before I get more derailed.
    Any opinion/suggestions would be appreciated.
    Thanks, much! [​IMG]
    Valerie
  2. Joe Szott
    Joe Szott Screenwriter
    Feb 22, 2002
    1,962
    Sounds like you got it going on Val, nice system for some 7.1. If you are happy now, consider yourself blessed: you can stick with what you got, or upgrade to 7.1 and make it even better. Either way, sounds like you'll be happy.
    380x is a good choice for that system. Others to cehck out might be the HK 52x or Pioneer Elite 45tx/47tx.
