John Gido
- Jun 18, 2001
I have a Yamaha RX-V595 A/V receiver and am using a Polk PSW350 for a sub. Which configuration will produce the least amount of distortion at near reference levels, LFE level on the receiver at "0" (-20dB to 0dB) & volume on the sub amp at "9 o'clock" or running the sub amp higher and the LFE output lower.
I would assume that the second option would be more efficient because the receiver LFE level (pre-amp) signal would be lower than the sub amp level (amp), thereby producing less distortion.
