Opinion on Mitsubishi WS-55313 (1 Viewer)
noletiger
chuck
First time here, I am thinking about buying an 04 Mitsubishi WS-55313 for $500.00 dollars. I plan on setting it up in my son's gaming room slash beginning theater room. Will Wii and PS2 work well on this set? It is a good TV as far as reliability and picture goes. Is there another reasonable used set you may reconmend.
Thanks Chuck
DanielM
Well I own the 65313 and have not had any problems with it Xbox and PS2 work just fine be aware there is only DVI no HDMI and the tv does not display 720p at all
Phil Carter
Austin, TX
Phil
Chuck, if you take DanielM's warning into account and you're OK with having no high-def video, you'll be pretty happy with the TV. I had a WS-48313 for years and was very happy with it.
cheers,
Phil
Kcuster50
