opening ports on my router?
Discussion in 'Computers' started by Christ Reynolds, Apr 22, 2003.
  1. Christ Reynolds
    Christ Reynolds Producer
    May 6, 2002
    3,597
    CJ
    how exactly would i do this? i use a program called bit torrent to download pearl jam concerts, and i read somewhere that you need to open up certain ports on your router to get better speeds. i have a cable connection, and im getting between 1k/s and 8 k/s, something is wrong here. anyone know how to do it? thanks for any help.
    CJ
  2. Christ Reynolds
    May 6, 2002
    3,597
    CJ
    ok i figured out how to do it, now i need to figure out which ports i need to forward to my router.
    CJ
  3. Joe Hsu
    Joe Hsu Supporting Actor
    Jul 2, 2001
    812
    This FAQ should have what you're looking for, looks like the port range is 6881-6889. Good luck with BT, I haven't had much luck with it myself...granted, I've barely used it.
    Let me know if it really makes a difference too, since I never opened extra ports, but was able to get up to 20K, regardless...maybe you were just getting an unpopular file.
  4. Christ Reynolds
    May 6, 2002
    3,597
    CJ
    i opened up those ports, and for me, it makes a substantial difference. i was downloading a 1.5gb vcd, and i was getting about 1-2k/s, and after i opened up the ports, i was getting about 30-80k/s. you should try it too, i think you will have much better luck with bt.
