I am in the process of putting together the equipment for my new home theater. It won't be on the level that a lot of people here do, as i will not be building or modifying a room, but using my current living room.
My living room is 16x18 with 10' ceilings. I plan on putting the tv on the north wall and the couch on the south wall, this is the 16' length. I can't use the 18 because that is where the door is. Anyways, the West wall is solid with the front door there while the East wall is wide open to the Dining room. Is this going to cause a problem for me? Will it even be worth it for me to buy a good sound system if i won't be able to enjoy like I was meant to due to the open wall?
Thanks for any info.
Oh, I will also be replacing the carpet and taking this time to run the wires for the rear speakers. Can i go straight across under the the carpet, or should i follow the walls? And all i need is the regular Speaker Cable right? I will be running the cable a week before I order the equipment so I need to make sure i run the right cable while the carpet is up.
Am I assuming this is easier than it really is?
Paul
Paul
