Open back wall = monopole side for 7.1?
Discussion in 'Speakers & Subwoofers' started by Allen_N, Aug 12, 2004.
  1. Allen_N
    Allen_N Stunt Coordinator
    Jul 30, 2004
    72
    I currently have a Klipsch RF-25 and RC-35 setup that I have just purchased. My wife and I are building a new house where the living room and kitchen are one huge room. I am wanting to do a 7.1 system where I envision using in-ceilings for my rear backs. However, for my surrounds I was wondering if it would be better to use a bookshelf speaker (RB-35) or the surround speaker (RS-25/35).
    Since there is no back wall close for the dipoles to bounce off of I was thinking it would be better to get the bookshelves. Is this correct thinking?
    Here is a link to the floor plan
    http://www.4atvtires.com/uploads/pro.../floorplan.JPG (Picture is 130k)
    I'll be moving the fireplace to the corner and placing my tv in it's spot.
  2. DavidCooper
    DavidCooper Stunt Coordinator
    May 21, 2004
    230
    I have a similar set-up. No back wall that opens into the dinning/kitchen area. I haven't tried dipoles for sides yet...but I would think they might not work as well.
    I'm currently using Monopoles and I think they sound pretty good. They can be a tad distracting on some material but I really think they do a great job.
    I'm just not sure the sound will change all that much if I went with dipoles...at least not for the cost increase!
    I would think your in the same boat....I think monopoles would be best.
