Onyx Reference 3 Towers
Discussion in 'Speakers' started by Shane Morales, May 2, 2004.
  1. Shane Morales
    Shane Morales Second Unit
    Jul 9, 2003
    433
  2. Alex Prosak
    Alex Prosak Supporting Actor
    Dec 9, 2001
    773
    Good things were said about them at CES. Not too many on these shores yet. Here's a review from Audio Circle. Another owner still owes a review.
  3. Craig Chase
    Craig Chase Gear Guru
    Oct 21, 2002
    1,615
    46
    Pennsylvania
    Craig
    I am working on a review now... and they are the most transparent dynamic speaker I have ever heard... they rival Quads, while having the dynamics of Klipschorns...
    I absolutely love these speakers...
  4. Cam McFarland
    Cam McFarland Supporting Actor
    Feb 6, 2004
    699
    Pardon my ignorance, but, could you put this
    in more laymans terms....:b
  5. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    Transparent = you can't pinpoint where the sound is directly coming from.
    Dynamic = versatile, sound can be played through the entire spectrum without virtually any limitations.
    Given that my total audio/theater budget has never been greater than $4k, I doubt if I'd ever see a pair of these fine Rockets in my home. However, at 105 Lbs. each, there is some heft to them. [​IMG]
  6. Cam McFarland
    Feb 6, 2004
    699
    Once again.......
    WAYNE TO THE RESCUE!!!
    thanks [​IMG]
  7. Craig Chase
    Oct 21, 2002
    1,615
    46
    Pennsylvania
    Craig
    Sure - A dynamic speaker is one that uses cones, domes... etc... There are also Ribbon speakers (Magnepan, Newform Research ... though Newform uses cone woofers), Electrotatic designs (Martin Logan, Quad) ....
    A Dynamic Loudspeaker has its advantages in that it can usually play louder than the Electrotstatic designs, thus giving a higher "dynamic range".
    An Electrostatic speaker, especially Quad, is a very transparent sounding speaker... very little stands between you and the original recording.
    The Ref 3's have the ability to do both. They will play as loud as you want, and do so easily, while giving that "see through" quality normally associated with speakers like Quad.
    There is a start....[​IMG]
  8. Cam McFarland
    Feb 6, 2004
    699
    my head hurts....
    but thanks anyway....lol
  9. Tony Genovese
    Tony Genovese Supporting Actor
    Oct 5, 2000
    811
    What would you consider "layman's terms" to describe the sound of a speaker?
    Transparent = see through, as in clear
    Dynamic, see meaning 4 here:
    http://dictionary.reference.com/search?q=dynamic
    Would you have preferred "They sound good". [​IMG]
  10. Joey_V
    Joey_V Second Unit
    Apr 13, 2004
    354
    i always though transparent meant clear.. like if the speaker was a window and the audio source is the outside view... then if the window was transparent enough, you could see the outside pretty much as it were intended to be seen.
    same thing for speakers!
