1. The HTF Tapatalk application has been discontinued. Please see the thread in the Forum Help & Feedback area for more information.
Onscreen logos burning in...
Discussion in 'Archived Threads 2001-2004' started by Doug Kennedy, Nov 2, 2002.
  1. Doug Kennedy
    Doug Kennedy Auditioning
    Oct 18, 2002
    10
    Is this still a problem even if the station is constantly showing commercials ie: every 10-15 minutes? I would think that going to commercial, with the logo disappearing, would lower the possibility of burn-in. Is this true?
  2. John-Miles
    John-Miles Screenwriter
    Nov 29, 2001
    1,210
    i dont think so........ the thing with the burn in is that it happens a little at a time EVERY time, so that would definitely slow it but may not stop it.
    I will add though that my friend has a 43" sony and we play HOURS and hours at a time with various video games, ive enver seen a sign of burn in, and some of those games have big static icons.
    I think alot of ppl worry about burn in too much, but you still have to be aware of it, thats what counts.
  3. MikeyWeitz
    MikeyWeitz Supporting Actor
    Feb 10, 2002
    939
    If calibrated with VE or avia, or at least contrast turned down to sub 45-50 levels, you should not worry about burn in too much. Keeping contrast low will severly slow it down, almost to a crawl.
  4. Kelley_B
    Kelley_B Cinematographer
    Feb 27, 2001
    2,324
    Or you could go with a DLP or LCD set as I believe neither of them suffer from the dreaded burn in issues.
  5. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Yes, with the white and black levels reduced way low, burn-in is slowed. Vary your programming mix as often as possible, and try avoiding stations with those damn station-bug logos (a near impossibility these days, unfortunately). And, of course, you could always make DVD your primary signal source! (Watch "television" on a secondary set, if practical.)
  6. Mark.D
    Mark.D Agent
    Oct 2, 2002
    36
    Here's a dumb question... eventually I'm going to go with a front projector... obviously, those images wont be burned into fabric screen.
    BUT, what about the projector itself? I have no idea what the internals of a front projector entail... is it possible for an image to be burned in somewhere in the projector itself?
    M.
  7. Jack Briggs
    Jun 3, 1999
    16,738
    129
    If it's a CRT-based projector, then, yes, burn-in occurs (on the phosphors coating the inside of the CRT lenses).
  8. Arthur W
    Arthur W Auditioning
    Feb 4, 2002
    14
    Hey Jack,
    What about LCDfront projectors? Any problems with burn in on those? I use an Eiki LC-XM1 in my home theatre and I have often wondered if those annoying station logos could "burn in" to the LCD pannels of the projector.
    - Chuck
  9. Guy Usher
    Guy Usher Supporting Actor
    Oct 20, 2002
    780
    DAMN the Sniper and CNNs BREAKING NEWS even if it does not harm the TV it sure burns me.
    BTW my friend has a Mits 46805, has had since the day that model hit the streets, he leaves it on almost 24 hrs a day , no cable, no sat., no OTA, only uses it to play widescreen movies, black bars all the time. Today over 3 years later not a trace of burn lines. I remember ruining good TVs with "Pong" didn't take long either.
    I try to avoid "logos" etc but anymore if you watch comercial television they are a fact of life, I have heard 911 ruined a lot of TVs, notice the "crawl" at the bottom of the screen, I like news but I am really tired of this crap. . .
  10. Jeff_M
    Jeff_M Stunt Coordinator
    Nov 26, 2000
    155
    Arthur W,
    Digital projectors such as LCD and DLP are not succeptible to burn-in. So go ahead and leave that test pattern on all night (assuming you're not concerned with bulb life).
