Only one sup pre out
chris bruce
I am running 3 subs and the receiver has 1 sub pre out. Is there a y cable that has 1 male and three female. I know I can run a normal y cable then another y cable into that. But I would like the less wires possible. I looked on the internet and am having no luck. Thanks
John Garcia
NorCal
Use 2 Y splitters. Do a search here also, as there is more than enough info covering the use of multiple subs.
3 subs will be difficult to calibrate properly.
gullfo
