Stephen Matthew
- Dec 20, 2001
i am currently building some cabinets for home theater use, 4 ohms unfortunately...my question is whether the onkyo txsr501 will handle 4 ohm loads.. i saw a recent review which showed that the model cut power drastically at full volume, and im wondering if the same protection circuit would kick in on a 4 ohm load.. i have an old pioneer POS which gets toasty at 4o hms but has no problems otherwise, and id like to upgrade to a quality reciever...
also, do the harmon kardon models do as much power per dollar in actual output as the onkyo's? i work at a dealer for both so it is one of the other, but when comparing the 25watts/channel less id get from the HK units i have to wonder...
thanks!
thanks!
