kevinBO
- Jan 10, 2005
Good morning, all.
Has anyone else experienced problems with the remote on this unit? I am on my 2nd unit now. With the 1st unit, neither the codes for other components nor the learning feature for other components' remote controls worked (where you point the 2 remotes at each other and it is supposed to learn that function). I returned it and got another. On this one, none of the codes work, and only a small amount of commands have worked from a learning remote perspective. However, strangely enough, it controlled my Hitachi TV out of the box, so that was a positive.
Has anyone else experienced this with this model, or other models with the same feature?
