Tomas_F
- Feb 20, 2004
Here's the question. On page 26 of the user manual it says:
Notes:
The Center and Subwoofer distances should be up to 5 ft.
more or less than the front distance. For example, if the
front distance is set to 20 ft., you should set the Center and Subwoofer distances between 15 and 25 ft.
I read it somewhere here in the forum that this is regarding delays.
Does it really matters if I set the Center and Subwoofer distances 5 ft. more or less than the front distance??? Base in your own experience what is the best setting???
Thanks.
Notes:
Thanks.
