Brett DiMichele
- Sep 30, 2001
- Brett
Hello Folks,
As the title refers I am using the DS787 from Onkyo.
My question is this, Have any of you ever sent the
receiver into protection mode? (kicked it off from
playing it too loud) Or am I the only one who has
had this problem?
I am running AR9's for front L/R and an AR C225PS for
the center and 2 AR 216PS's for the surrounds, they are
all 8ohm and are all wired with quality wire.
I was watching A Bugs Life this morning in THX-EX mode
and sure enough half way through she kicked off. Could
it be that my A/V rack is not allowing enough ventilation
to the side and top of the unit which causes the thermal
protection to kick in? It does get fairly warm.
Another question is this.. I don't have Avia or anyting
worth while to go through and set up everything yet. I am
curious what do other DS787 owners run thier mains,center
and surround at? the scale goes from -12Db to +12Db and I
usualy run them all at 12Db. Also what do you have the
Intellivolume set at?
Just curious..
had this problem?
Just curious..
