John_Drake
Grip
- Oct 25, 2002
Hi Everyone...
I am new to the HT Forum although I have been reading these forums for quite some time now. There seems to be a lot of experienced people here so I need some educate opinions.
I recently purchased a Toshiba 65HDX82 HD-RPTV and now I would like to upgrade my sound system. I want to replace my old Sony (Sava) Pro Logic system but I don't want to spend a lot right now.
I am debating going with either the Onkyo TX-SR600 or the Pioneer VSX-D811S. I am also thinking of using one of these receivers with the Onkyo SKS-HT500 Surround Speakers (8ohm).
The main reasons that I am looking at these particular models is 1) $Price$, 2) Ratings (CNet.com gave them Best Buy rating).
I am pretty much sold on the speaker package after playing with them in the store and because of their price ($269).
My main debate is on the receiver. I have listed the main differences that concern me below.
Here Is My Comparison:
1) Pioneer is $100 less than the Onkyo
2) Pioneer is rated 100Watts per channel/Onkyo is 80Watts
3) Pioneer has 7.1(matrix, I know) Channel inputs/Onkyo does not
4) Pioneer has Frequency Response 5Hz-100kHz/Onkyo is 10Hz-100kHz
5) Onkyo 50MHz Component Video Switching/Pioneer has 28MHz
6) Onkyo can do 8,6,4ohm speakers/Pioneer only 8ohm
7) Onkyo has .08% Total Harmonic Distortion/Pioneer has .2% THD
8) Onkyo has 96 & 192kHZ 24Bit DACs/Pioneer has only 96kHz DACs
9) Onkyo has Crossover Adj.(80,100,120Hz)/Pioneer is (100,150,200Hz)
10) Onkyo has On-Screen Display/Pioneer does not
Other Components I Have:
1) Hughes Platinum DirecTV receiver (not HD) via S-Video/Optical Digital Audio
2) Pioneer DVD Megachanger (F707) via Component Video/Optical Digital Audio
3) Panasonic VCR via composite A/V
4) Sony Playstation via S-Vid and Composite Audio
I am planning to upgrade my DirecTV receiver in the near future, but will probably connect via DVI.
My room is 19'x12' rectangle, 2 tiers of seating, stairs behind the back couch.
I know these are all tech specs, but I could use some opinions on them as well as sound quality, durability, usability, etc.
Some of my questions are:
1) Should I really be concerned about the Component Video Switching? I only have one Component Vid Source and One S-Vid source. Should I even bother running them through the A/V Receiver, or leave them direct connect to the TV?
2) What are the 2 different DACs on the Onkyo receiver?
3) Should I go with the 100Watt Pioneer or the 80Watt Onkyo that can handle better speakers down the road?
4) Sound Quality! This is a biggy. I don't have the ability to try this out before-hand and compare.
Sorry if this is long and I hope I don't sound too ignorant. I am fairly new to home theater and could use the advice.
Thanks for any input you can provide.
