ThomasL
- Mar 13, 2001
I'm thinking of purchasing one of these receivers as a new receiver for a small home theater setup. The SR600 and Marantz 5200 have 6 amplified channels including the rear center. In my room's current configuration, it will have to have 2 rear centers on each side of a window which sits in the middle of the wall behind the couch. Would it do great harm to wire both of them in parallel off of the one channel on either of these receivers? We do not listen to our system at reference levels and the room is small so I don't feel we'll be coming close to clipping. But anyhow, I'm wondering if the Onkyo in particular will not like this arrangement. I notice it has a switch in the back telling it what ohm rating one's speakers are at and thought this might cause problems if it sees a 4 ohm load on that one channel. Does anyone else have 2 rear centers wired in parallel off of one amplified channel?
And with regards to the Pioneer model, it has two outputs on the back for 2 speakers yet just one amplified channel so I suspect it has wired these in series. Can anyone who owns the D811S verify that?
thanks,
--tom
thanks,
--tom
