you can reset the settings by holding video-1 while powering up. It should respond with "clear" in the display. It is likely, however that you will have to follow the advice given in the manual-- namely "Contact your Onkyo dealer"
that happened to me, but what happened was a beer tab had somehow lodged itself between the speaker terminals. check every connection, or pray for warrenty service.
