Onkyo HT-S8230 = HT-S570?
Discussion in 'Speakers & Subwoofers' started by Tim Holyoke, Jan 6, 2005.
  1. Tim Holyoke
    Tim Holyoke Second Unit
    Nov 6, 2002
    268
    I'm in the market for my first, lower-end, HT setup. I had been looking at the HT-S570 from Onkyo, and saw a system (Onkyo HT-S8230) at Radio Shack for $250, $20 or $30 less than the 570 at Circuit City. The specs of these systems look basically the same, as do the systems themselves. Are they the same, just with different model #s?
    Anybody have either? How do you like them?
    Thanks a lot for any help.
    Tim
  2. Tim Holyoke
    Nov 6, 2002
    268
  3. steve nn
    steve nn Cinematographer
    Jan 12, 2002
    2,418
    Yes, they are the same unit. I picked one up for the den and gave the sub to a friend. After intergrading the SVS PB10-ISD into it-it does just fine hooked up to the computer. If your on a tight budget, I would swap out the sub and go with http://www.partsexpress.com/pe/showd...number=300-632 when it's on sale for $99.
    How does it sound? Well after swapping the sub it's much better but nothing like my reference system. Never did expect it though. The receiver has many crossover points starting at 60 and 20-20 rated. Swap the sub and it'll be a good start and then the speakers as budget permits.
  4. Muhammed
    Muhammed Agent
    Oct 19, 2003
    40
    Some Fry's stores had this on sale recently for $199, but that's pretty much regional (they're in Texas, and along the West coast I believe).
    As a starter system, it's pretty decent.
