OK - Out of the box, looks perfect, just a slight dimple in the sheet metal where it mates up to the front panel - not visible without close inspection. Remote and manual are new.
Runs fine - I'll watch a few of my greatest hits and see how it compares against my 4-5 year old Sony DVP-S300.
This will also be the first time I have EVER heard dts in the home...
Colin, I'm willing to be that you'll get your 100 bucks worth when you use it in progressive mode. If you have any buddies that have a tv that can take a progressive scan signal, you may hook it up and see something that you like quite a bit. My early Toshiba is very sharp and had the jaggies but through component cables and through the tv's line doubler on my 55" HD, it looks much improved. I'm sure your player will look even better w/ prog hook up.
