Onkyo DS 595 Remote... Can't Progam.. Help!!!
Discussion in 'Archived Threads 2001-2004' started by Josh Sooy, Jan 23, 2002.
  1. Josh Sooy
    Josh Sooy Auditioning
    Dec 19, 2001
    7
    I am following the instructions for putting in preprogrammed codes for my tv, vcr, satelite, etc. I am followin ghte instructions exactly but the stupid thing wont learn.
    I hit the key of the mode I want.. ex. (SAT)
    then I hold Mode then hit Display... the lights go off...
    I type in the code... nothing happens... its supposed to have two light blinks... wahts up.. I am gettinf frustrated.
    Thanks, Josh
  2. AaronMontgomery
    AaronMontgomery Auditioning
    Jan 26, 2002
    4
    I just got my 797 last night and was having a bit of the same frustration. I think the manual just isn't written very well. The diagrams seem to be a bit more helpful.
    I think the "mode" button really refers to the device (dvd/v1/etc) as that whole group of buttons appears to be called "mode".
    I had luck by pressing the mode button (cable), the display button (lower left) and releasing at the same time. Enter your code and it blinks appropriately.
    I couldn't find any good codes for my Sony DVD player and my General Instruments cable box used a different code (not GI) and I still had to program some keys for that. I'm going to work on the DVD remote tonight.
    Hope this helps,
    Good luck!
    Aaron
