Joe Pick
- Jan 12, 2004
I sure hope someone can help. I have an Onkyo TX-SR703 AVR connected to PSB Image Series speakers (5T left and right, C40 center, 2B surrounds). I've done the speaker calibration with the included setup mic, but my center speaker's tone sounds audibly quite different from the left and right fronts. Not bad, just different. Not quite as clear or defined. When watching the "Cars" DVD, many times voices travel from left to right, passing through or stopping in the center. The voices (Luke Wislon for example) sound a little different when in the L or R speaker compared to the center. I'm using identical speaker wire throughout, and double-checked my connections.
My Onkyo has a manual equalizer setting that I thought might help, but I don't have a clue how to try to make changes. After doing the auto-setup, the settings are very different from speaker to speaker. If I want to make manual changes, here are the options for each speaker:
c. 80Hz : 0dB
d. 250Hz : 0dB
e. 800Hz : 0dB
f. 2.5kHz : 0dB
g. 8kHz : 0dB
Each band can be cut or boosted from –6 dB to +6 dB in 1 dB steps. Onkyo tells me that low frequencies (e.g., 80Hz) affect bass sounds; high frequencies (e.g., 8kHz) affect treble sounds. Since the left speaker sounds good to me, I tried to set up the center speaker with the same settings as the left, but I'm not sure if that did anything.
Does anyone have any ideas on how to set these up, or whether or not it will make a difference? Sorry to ramble, but I wanted to include as much info as I can think of. Short version: I want my center channel to sound very close to the tone of my L and R speakers. Thanks!
c. 80Hz : 0dB
d. 250Hz : 0dB
e. 800Hz : 0dB
f. 2.5kHz : 0dB
g. 8kHz : 0dB
