Onkyo 797 Help Please
Discussion in 'Archived Threads 2001-2004' started by Kyle_Y, Dec 29, 2001.
  1. Kyle_Y
    Kyle_Y Stunt Coordinator
    Nov 9, 2001
    238
    I just got my Onkyo 797 and I am very happy with it. I jsut noticed, when I was moving it, that the side panels, do not fit very well, or maybe this is how it is meant to be. At the bottom of the middle of the side panel, I can push it in, and it pops back out, about .5cm, is this somethign to worry about? Also, I saw a fan on the inside of the 797, when does it kick in, is it based on temp or on output? Thanks.
  2. Scott Stegner
    Dec 23, 2001
    23
    I just got my 797 yesterday. I also noticed the case has some clearance on the sides between it and the unit frame. Nothing to worry about although it does not lend to what I think of as quality construction.
  3. Seth T
    Seth T Stunt Coordinator
    Dec 8, 2000
    185
    I thought the exact same thing...they should have have had another screw on each side in the center. Made it feel a little cheap when taking it out of the box.
    On the other hand, it's sitting in my entertainment center, and I'd forgotten all about it until you guys brought it up. [​IMG]
  4. PaulCK
    PaulCK Auditioning
    Nov 6, 2001
    12
    WHEW!! I thought that I was the only one with that problem!
