Onkyo 705 - Zone 2 and 3 Speaker/volume control connections (1 Viewer)
BRay11
Bill
I am a novice in need of advice:
I recently did my basement into a home theater. In addition to the TV area, I wanted 2 additional listening areas in other rooms in the basement with their own separate speakers (2 speakers for each zone - 4 total) on their own separate volume controls (wall control in each area - 2 total).
I ran the wiring for this: 2 speaker wires from receiver to each of the wall volume controls, then obviously speaker wire from the wall control to each of the speakers. Each zone (wall control) is separately wired back to the receiver - NOT wired "in-line" from receiver to zone 2, then from zone 2 to zone 3.
I bought the Onkyo 705 to run all of this - which I am VERY happy with. TV area 5.1 sound is great and works fine. However, after reading the manual (several times) I am now very confused about how to wire these other 2 zones into the receiver. I admit I don't fully grasp the "impedance" issues that go with wiring the speakers/volume control.
I have been told I need a device called a "match-it" (?) to accommodate the 2 additional zones/speakers I have. At this point I am somewhat lost.
(1) I can't figure out what this "match-it" is, why I need it and how it fits in to the set-up if I do need it, (2) whether there are any particular requirements I need to have in the wall volume controls for the 2 extra zones, and (3) how to wire this set-up into the Onkyo 705 to be able to send different outputs (different from that playing in zone 1/TV area) to these 2 other zones.
Any help or advice would be very much appreciated. Thanks
David Willow
Babbling Idiot
Mechanicsburg, PA
Dave
The 705 has zone 2, but not zone 3. On the back of the unit you will find additional posts labeled for zone 2. Hook you speaker up there. You will have to turn them on in the menu.
Beware that only analog sources can be played thru zone 2.
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Can you post a link to the manual? You will still need a impedance-matching device of some kind to run all those speakers from the Onkyo. Maybe a speaker selector switch from Radio Shack or Parts Express.
Like David said, digital components can be a problem with secondary zones if you have the connected to the Onkyo with only coax or optical connections. An easy work-around is to add the analog connections from the component to the receiver, and you should be in good shape then.
Wayne A. Pflughaupt
andriesprice
