Onkyo 602 Vs Yamaha Rx 657
Discussion in 'AV Receivers' started by mattSA, Feb 14, 2006.
  1. mattSA
    mattSA Auditioning
    Feb 13, 2006
    4
    Can someone tell me what the better one is.
    I have the 602 but it is playing up and the company now said they will upgrade it to the Yamaha..... is it an upgrade ?
  2. Reginald Trent
    Reginald Trent Screenwriter
    Feb 18, 2000
    1,313
    What do you mean my "it is playing up"?
  3. mattSA
    mattSA Auditioning
    Feb 13, 2006
    4
    the picture when run via component has a vertical line that looks like a hair on the projector lens. it goes away when run via s-video.
    The company I brought it all from said that it is a problem with upscaling.
    they fitted a Onkyo 603 but it did the same so now they think the Yamaha will fix the problem
    Cheers
    mat
  4. DougR
    DougR Second Unit
    Jun 15, 1999
    354
    Did you try using a diffeent set of Component Cables ?
  5. mattSA
    mattSA Auditioning
    Feb 13, 2006
    4
    I did suggest that to the guy but he said because it worked direct from the DVD and S-video it could not be the cables.
    I am starting to wonder if they know what they are on about
