One more h/k 520 ? Is the 520 compatible with 96kHz/24bit dvd-A?
Discussion in 'Archived Threads 2001-2004' started by Todd smith, Apr 12, 2002.
  1. Todd smith
    Todd smith Supporting Actor
    Apr 2, 2002
    643
    Just wondering if this receiver is 96kHz/24 bit compatible with for dvd audio? What exactly is dvd audio? (dvd-A)
  2. Earl Simpson
    Earl Simpson Supporting Actor
    Jan 12, 2002
    803
  3. Todd smith
    Apr 2, 2002
    643
    Thanks for the info. I assume that all this means it is compatible. I assume that 192kHz/24bit is even better than 96kHz/24bit, is this correct?
  4. Earl Simpson
    Jan 12, 2002
    803
    Yeah, maybe, probably, I guess, every odd thursday. Boy that JVC sure looks nice.
  5. Jeff Keene
    Jeff Keene Supporting Actor
    May 18, 2000
    514
    Hi Todd --
    This may not answer your question, as I'm too lazy to look up the 520 to see if it has this... but... all the receiver needs to be "DVD-A compatible" is a set of 6 (or 5.1) channel analog inputs.
    Because of copy-protection issues (read: nonsense), digital connections are not yet available that allow DVD-A bits to be processed by a receiver. So while a 96/24 (or 192/24 for that matter) may aid you in other ways (over-sampling, not sure on DD/DTS, etc.) it will NOT help you with DVD-A at this time.
    Without getting technical (since I'd get it wrong), DVD-A is a format that uses the capacity of a DVD and lossless compression to give you 6 channels of 96/24 resolution for an audio program (vs 44/16 or 48/16 x 2 on a standard CD).
    This added resolution allows greater dynamic range and frequency response, as well as a more "analog-like" sound (due to the higher sampling rate).
