MikeBoehm
- Dec 1, 2001
Howdy,
I was at my local Menards (Home Improvement store) and saw some wall plates that have speaker ports on them. I'm not sure what quality they are (Maganavox brand). Is it better to just run a single cable from the receiver, up the wall, across the ceiling and to the speaker or will I not notice much different if I run the wires to the speakers and end them at a wall plate and then plug the wire from the receive into the wall plate.
Only reason would be to make it look cleaner with a plate than having cables sticking out of the walls.
--Mike
--Mike
