Omnimount for polk rm6700
Discussion in 'Speakers' started by BurtS, Feb 25, 2004.
  1. BurtS
    BurtS Stunt Coordinator
    Feb 1, 2004
    60
    Which of these 10.0 mount is the one I need the 22.99 one or the 19.99 one. Also does anyone know any cheaper mounts then these to mount polk rm6700 to my wall. These come to 120.00 with shipping to Hawaii.
    http://www.racksandstands.com/asp/ke...mmand=dosearch
  2. Frank Zimkas
    Frank Zimkas Supporting Actor
    Mar 10, 2002
    888
    These are the ones you need. Join the Polk Audio Forum here and when you order them from Polk tell them you would like the Club Polk discount.
  3. BurtS
    Feb 1, 2004
    60
    That link didnt work for the brackets OmniMount 10.0 RWX Extended Arm Bracket , is that the one for $24.99, the mounts in my link wont fit?
  4. Frank Zimkas
    Mar 10, 2002
    888
    I think I've got it working now.
  5. BurtS
    Feb 1, 2004
    60
    Yikes Those are Mega Expensive, will the ones in my link work this is for the light weight rm6700 sattelites
  6. Frank Zimkas
    Mar 10, 2002
    888
    Yes they will.
  7. BurtS
    Feb 1, 2004
    60
  8. Frank Zimkas
    Mar 10, 2002
    888
    I guess you'd have to check the thread size in the speaker to see if it's the same as the mount (1/4-20). The Polk site does not list the thread size.
