EddyObregon
- Jan 12, 2004
Ok when i bought my Atoms the dealer told me to buy the omni 10 for mounting. Well I have been more than 4 hours try to mount. I had to return 2 of them and get 2 new ones because every time i tighten hard enough the ball bearign slips and the speaker does not hold in place. I got one side to work but the other has been a nightmare the instruction booklet says you have to make sure that it gets a good grip. It says exactly that it needs to get a good bite. I have tired for numerous hours and it keeps slipping has anyoen had this problem and are the paradigm mounts for the atoms pretty much the same do they stick out a couple of inches fromt he wall and can i tilt them and all that stuff. Please help i am goign crazy..
