Older DVD Movie Size
Discussion in 'Archived Threads 2001-2004' started by Bill Lide, Oct 22, 2002.
  1. Bill Lide
    Bill Lide Extra
    Jul 18, 2002
    21
    I have a question for you guys. I own a 57' Sony 16:9 TV and I have done all the setup on the TV and my DVD player. And I have a somewhat understanding of the different movie formats. But I played an older DVD (Armagedon) and a new movie (Lord of the Rings) which are both 2:35 I believe and the Armagedon movie is smaller than Lord of the Rings. Why is that? Do older moves have a different output to the screen?
    Thanks for your help...
  2. Jim FC
    Jim FC Stunt Coordinator
    Feb 5, 2001
    211
    The version of Armageddon that you have may not be an anamorphic DVD. As I recall, the original printing of that movie was one of the last DVDs to not be anamorphic. If you have this version, it may be noticeably smaller vertically, and people will look a bit stretched from side-to-side. You can tell an anamorphic DVD by the words on the package: "Enhanced for Widescreen TVs."
    To clarify: an anamorphic widescreen DVD is recorded in a squareish shape with a vertically stretched image, and then the DVD player "squishes" the image down to bring it to the correct aspect ration, as well as to return the image to its non-distorted state. This is done to enhance picture resolution on widescreen TVs. If Armageddon is not recorded in that way, and your DVD player is still squishing it, you're going to get a really skinny picture. Try going into your DVD's setup menu and choosing "4:3" as your TV type instead of "16:9." Then play Armageddon. If it then looks correct, then we've nailed the problem.
  3. elMalloc
    elMalloc Supporting Actor
    Dec 26, 2001
    787
    I thikn I read armageddon was labeled wrong?
  4. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Actually, because the earlier DVD version of this, um, movie is widescreen letterboxed-only. It's a 4:3-encoded DVD of a widescreen transfer. Because of that, the Sony is windowboxing the entire image, preserving the entire frame but, in the process, scaling its size downward. The 16:9-encoded DVD will fill the screen from side to side.
  5. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    I don't know if this is the case but often times, many movies are not exactly 2.35:1. I have seen 2.20:1 and 2.10:1 aspect ratio movies despite the fact that the bx claims 2.35.
  6. Doug_L
    Doug_L Stunt Coordinator
    Jun 22, 2000
    124
    Just a quick correction for Jim FC:
  7. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    Armageddon isn't anamorphic, either in the original or the Criterion Edition.
    When shown on a widescreen set in "Full" mode, it will be vertically narrower than an anamorphic dvd of the same OAR, and the geometry will be off (everything will look short and fat).
    The set should be put in "Zoom" for nonanamorphic widescreen dvds, and "Normal" for 4/3 (1:33) dvds.
