Older Bryston vs newer Rotel amps?
Discussion in 'AV Receivers' started by RonW, Nov 10, 2003.
  1. RonW
    RonW Extra
    Sep 14, 2003
    17
    I am looking for a two channel amp to use with my Denon 3803. The 3803 will power the center and surrounds while the two channel will do the mains which are B&W Matrix 803's. I can buy a used Bryston 3BST for around $600 or a Rotel 981 or 991 or even a 1080 for about the same amount. I am not concerned with volume, I am more concerned with clarity, soundstage, openess etc. Any thoughts?
    Ron
  2. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Bryston. Easy. [​IMG]
    Go check out some of the old reviews. Stereophile has a few, and actually, both Bryston's and Rotel's web sites have reviews. Make sure to find reviews with measurements. I have never ever read a bad review of a Bryston. I *have* read less than 100% positive reviews of Rotel amps. Rotel makes great amps. But Bryston is in an entirely different league.
