Old Tv Only Bringing In Cannels 2 - 13 (1 Viewer)
Jarett
hey all,
I have a fairly old emerson 13" tv that i hooked cable up to. The problem is it only gives me channels 2 - 13 when i should be getting 2 - 24. It has a chanel switch thingy on the back fro 3 and 4 but it doesnt do anything....i have no remote for it....anyone know what the problem is? Thanks
Jay
Drue Elrick
Some old TVs only had tuners that worked up to channel 13. And I mean OLD. Either way, I'd suggest using a VCR to tune and change channels. Repairing will likely cost more than the cost for a new one.
Brian Gi
I have a 1993 hitachi 13" that only tuned 2-13 until I got a remote that had the menu function, I switched it from "Air" to "Cable" and it works fine. It's now in the smoking lounge. (Garage)
Jarett
hey,
it actually has like up to channell 100 but past 13 they are all fuzzy...i'll try a vcr
thanks
Allan Jayne
A non-cable-ready TV will only get channels 2-13 off of a cable with no cable box and then only if those channels are analog and not scrambled.
Channels 14 and up for cable are on different frequency bands than channels 14-60 over the air. A few might come in as different channel numbers (if analog and not scrambled) if you connect the cable to the UHF jack rather than the VHF jack behind the TV. You will need a 75 ohm (jack) to 300 ohm (pigtails) transformer if the TV has screw terminals instead of jacks for the antenna connections.
Video hints:
linda19798888
