Chuck Mullen
- Jan 23, 2004
Here we go.
My wife brings home this TV that her Grandmother gave her and I'm trying to hook up cable to it. It is definitely not cable-ready. I have a F-connector to spade clip converter and an analog cable box, should be good to go right?
Nope.
This TV has two tuner buttons on the front that work like an FM radio tuner. You press and hold the button and the set slowly changes channels up the dial. The problem is there is no indication what channel you are on unless you can tell what from show is on. I have tried holding these buttons till my finger bled but I can't find the cable signal.
B.T.W. there is no channel 3-4 switch on the cable box like on a VCR.
Any ideas?
Nope.
Any ideas?
