old technology
Discussion in 'Archived Threads 2001-2004' started by Julio, Jul 4, 2002.
  1. Julio
    Julio Agent
    Jul 3, 2002
    43
    I get the feeling after reading a few post on another NEWSGROUP that I bought old technology
    on my receiver what am I missing on sound do I miss alot for not having DTS-ES and DD EX and DPL II
    on my dvd player do I miss alot for not having SACD or DVD-A
    if SACD and DVD-A is just music with surround sound then I don't think I'm missing much
    receiver is STR-DE1075 no DTS-ES no DD EX no DPL II
    dvd DVP-NS700P no SACD no DVD-A
    I got my receiver 3 months ago and my dvd player like 3 weeks ago I can't believe is time to upgrade already
  2. Chuck Kent
    Chuck Kent Supporting Actor
    May 29, 1999
    983
    If 20 of us answer, you'll get 20 different opinions. That said, here my 2 cents worth...
    I've heard a fair amount of 6.1 sound (EX and ES) and while it is another notch forward, I don't sit listening to my 5.1 setup trying to figure out when I'm going to upgrade.
    As for DPL II, my feelings are stronger. I moved both my main setup and my 2nd smaller system to DPL II after hearing it. I have found the full range/true stereo surrounds really add to my enjoyment. IF (and that is a BIG IF) you listen to 2 channel sources in surround sound, I believe DPL II is a very noticeable improvement. Especially in 2 channel TV or movies. (I do like what it can do with 2 channel music. But, I'm still an old dog and alot of the music I own still sounds good as stereo.)
    6.1 music??? I really haven't "listened" to it. There just isn't much available yet (ie. slim pickings/little catalog.) It may become important, but I don't find it so yet. (FWIW, if you want to see how much you like multi-channel music, buy a DVD-A disc. It will play as DTS 5.1 or DD 5.1 too. No, it won't be as good sounding as the higher resolution formats but it will give you a taste of how the 5.1 music will sound.)
    Bottom line, should you upgrade? IMO, no, not this soon. Budget-wise (unless you can return your stuff), you're going to take a spanking. But you might consider upgrading in a year or so...
  3. Julio
    Julio Agent
    Jul 3, 2002
    43
    thanks for the reply with what you said I'll stick with what I have now for a while then I will upgrade
