old receiver as amp for 2nd zone
Discussion in 'AV Receivers' started by sean f, Mar 28, 2004.
  1. sean f
    sean f Agent
    Jan 3, 2004
    35
    I have a Pioneer Elite vsx43tx running a 7.1 setup. Can I use this old JVC RxR 85 receiver to run 2 more speakers in another room by running an rca cable from the front pre-amp out on the Pioneer receiver to the aux in on the JVC then hook the 2 new speakers to the JVC? The JVC is quite old I Bought it in 1988 but it has taken a beating through the years and keep kicking. Does anybody have any specs on it? Thanks
  2. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Sure you can do this, it would be no problem. I'm using an old JVC RK-11 that I bought in 1983 for some in-ceiling speakers in my house. Works great. The only problem is you won't be able to switch it on automatically.
  3. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Doesn't the 43 already have outputs for a second zone? Why use the main pre-outs (unles you want to hear the same thing in both rooms)?
  4. sean f
    sean f Agent
    Jan 3, 2004
    35
    if i understand you right ther should be 2nd zone pream outs? I dont believe there is, if i rember right they are either b channel or surround back.
    thanks
