OK to use Safeway 99percent Isopropyl
Discussion in 'Playback Devices' started by GregC, Oct 30, 2002.
  1. GregC
    GregC Stunt Coordinator
    Feb 6, 2000
    136
    Alcohol in my Maxell Video Head Cleaner or do I need something specially formulated for electronics?
  2. JackS
    JackS Supporting Actor
    Jan 17, 2002
    634
    Someone may have an exact answer but I think 90% Iso-proply alcohol would be perfect. The only possible problem may be using too much which could allow the alcohol to enter or drip down into a mechenism which relys on some type of lubrication. The alcohol could in this case remove the lube and of course cause a failure. Instead of using a cassette type head cleaner, use Q-tips dipped in the alcohol and reach through the cassette door to clean, or better yet remove the top of the case which would allow for a superior head cleaning and pinch roller job.
  3. mike_decock
    mike_decock Supporting Actor
    May 21, 2002
    621
    Just make sure you don't get alcohol on the rollers or capstans. It dries out the rubber.
    -Mike...
  4. GregC
    Feb 6, 2000
    136
    Thanks. I'll be careful!
  5. Blaine Skerry
    Blaine Skerry Second Unit
    Aug 15, 2001
    277
    I would advise against Q-tips as cotton strands can become embedded in the video head causing more problems. If you can find cleaning devices with chamois or foam rubber coverings, use them instead of Q-tips.
  6. John*K
    John*K Stunt Coordinator
    Oct 20, 2001
    145
    Is there a kit available that includes the fluid and swabs? I am rediscovering my cassettes and NAD 6155 3-header. Sorry for kicking up an old topic.
