Ok Im still stuck on this, Yamaha vs HK?
Discussion in 'AV Receivers' started by Jesse Sharrow, Jan 29, 2004.
  1. Jesse Sharrow
    Jesse Sharrow Supporting Actor
    Jul 11, 2003
    745
    Ok Im still stuck on which receiver I want. Im looking at the Yamaha RXV-1400 or RXZ1. Im also looking at the HK-430 or 630???? Now is the power on all these units about the same? Also what is a major difference between the 430 and 630. I cant find anything but 10 watts. Well help me out guys, again thanks in advance.
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    yes, the lower power ratings that may be listed for the H/K's probably more than equal the Yamaha's.
    The 440 is considered an entry level by the company.
    The 640 seems like it is just a better all around unit.
    Hard to say, your right the feature list is very close.
    They make a point of telling you the 640 has very high quality DAC's though.
    I'm banking the 640, has better performance especially when cranked loud.
  3. Jesse Sharrow
    Jul 11, 2003
    745
    Are you talking about the yamaha rxv-440 and rxv-640? Or the HK AVR-430 and AVR-630?
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    OOops.. your right, I got cornfused... I think I looked up the Yammy units there sorry....
  5. Jesse Sharrow
    Jul 11, 2003
    745
    So wich one were you talking about? Im guessing the yamaha's?
  6. John S
    John S Producer
    Nov 4, 2003
    5,460
    yes, the Yamaha's.. Both those H/K units are not what I would consider entry level at all. So probably not so much of a difference there as with the two Yamaha units.
  7. Jesse Sharrow
    Jul 11, 2003
    745
    Well I just wanted to let you guys know that I decided to pick up the RXV-1400 on saturday. It has everything I need and nothing I dont. Plus is has the same remote Im using now, dont ask. Plus the harman kardon I would have to order through accomadation and it would take a while and my wife wouldnt like being without a receiver for a while. So thats my choice. If anyone cares, next I will be buying a PB1-isd or a PB2-isd. [​IMG]
    Thanks again guys, also I appologize about making so many posts, I will only do one from now on.
  8. John S
    John S Producer
    Nov 4, 2003
    5,460
    Thanks for letting us know your purchase choice.
    Come on back with a review of it once you get it installed and have some experiences with it.
