Alex_C
- May 12, 2003
I'm starting to narrow down the list. I do not want to spend more than $600.
I won't be able to listen to any of these so I'm going go by your opinions.
If you can think of any others I should take a look at, let me know.
H/K 525 Refurb $546 at onecall.com
Denon 2802 Refurb $472 at ebay authorized dealer
Yamaha 1300 $499 ... can't find authorized dealer
Yamaha 5660 $499 at Best Buy
Yamaha RXV-640 $499 at tweeter
I don't know much about the differences in the Yamaha's yet.
I need some guidance here since I can't listen to them.
It will be used for HT only.
The room is 22'x25' and I'm using DefTech 2006 fronts.
I'd like 6.1.
Thanks everyone!
I'd like 6.1.
Thanks everyone!
