1. The HTF Tapatalk application has been discontinued. Please see the thread in the Forum Help & Feedback area for more information.
OK I bought speaker stands for my Paradigm Mini Monitors. Need help..
Discussion in 'Speakers' started by EddyObregon, Feb 5, 2004.
  1. EddyObregon
    EddyObregon Stunt Coordinator
    Jan 12, 2004
    153
    Ok I bought some sanus metal speaker stands for my mini monitors. Now When I put my mini on the stands what can i do to prevent them from moving on the stands. My stand has 4 holes but did not come with any screws to prevent the seaker from sliding the dealer told me to get double sided velcro at home depot. He said that this would prevent the speaker from moving. Also the top plate is 61/2 by 6 and the mini monitor speaker is 8 witdh by 12 inches long .. since the mini monitor is a big long speaker will i have a problem with these stands. All the stands that i saw had basically the same top plate.
  2. EddyObregon
    Jan 12, 2004
    153
    ok guys can I use omnimounts for the paradigm atoms. Does it matter if i use the 20.0 or the 10.0 do they both have the same screw size that connects to the speaker. I bought the 20.0 and I am now worried if the atoms screw on to them correctly. Does anyone know of this.
  3. cabreau
    cabreau Second Unit
    Dec 1, 2003
    322
    If you go to a car parts store, you can get a roll of rubbery type stuff that is used to put tools on metal surfaces so that they don't slide around. You'll see the tops of most Snap On boxes with this rubbery stuff on them, it's sort of "woven" so that oil and dirt can fall through. Once you have that on there, your speaker WILL NOT move sideways, you have to lift it up to adjust it. That's what I use and it's great stuff. It works on a tv, wood, metal, any type of surface and it holds your speaker right in place.
    Here's one for woodworking...but it's the same stuff...
    http://www.rockler.com/ecom7/findpro...004&gtkw=Tools
    As far as the size of yor plate, go pick up some pieces of 1/2" to 3/4" wood at your local lumber yard (where you can probably pick up this non-slip pad too) and just screw a larger piece of wood onto the top of the plate, then place your speaker on that.
  4. EddyObregon
    Jan 12, 2004
    153
    ok but with the 6 inch by 6.5 inch hold up my speaker. Is this a normal top plate. If it is enough I will use the rubber pad. if not i can return the stand . do most speaker stands coem with this top plate deimensions
  5. cabreau
    cabreau Second Unit
    Dec 1, 2003
    322
    My Studio 20s hang off the sides of my speaker stands on all sides. This is normal. Just set it on the stand and try to tip it over, move it until it's in a spot where it's the same difficulty to tip in in all four directions. You'll find that it sits BACK alot, since most of the weight is in the front of the speaker, where the drivers are.
  6. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Blu-Tak or something equivalent can be found at your local hardware store for a few bucks. Works great.
  7. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Why not get Paradigm's own brackets which are specifically designed for use with their speaekrs? Your dealer should be able to order them for you.
  8. EddyObregon
    Jan 12, 2004
    153
    so do i add rubber tabs or velcro to prevent it from moving though
  9. GrahamT
    GrahamT Supporting Actor
    Sep 13, 2003
    556
    You could get the Premier stands that were made for the minis. Your Paradigm dealer should have them.
