Zak Solo
- Mar 19, 2001
This is probably the crassest question anyone is going to ask.
I have a Sony STR DB940 (which I love) and B&W 603 s2's and the CC6 centre. My rears are Celestion. All are 8 ohm rated.
Now I was just dusting and making sure all my connections were okay on the receiver and saw the 4ohm/8 ohm switch. It was on 4 ohm's. (I hadn't thought anything about ohm's until I saw the selctor switch).
The question is do I want the switch to be on 4 ohms or 8 ohms. I don't know anything about impedence is 4 hi or low? Does one give more power than the others?
