Samuel Des
- Feb 7, 2001
Because I've put in a lot of new hardware over the last year, I decided to do a clean re-install of Win Me. I backed up all data on a separate HD; erased and recreated the primary HD partition; formated the primary HD; and tested the boot disk that came with my Win Me. I then tested the boot disk to see if it worked -- it did.
But when I got ready to reinstall, the bootdisk FAILED! For some totally inexplicable reason, the media was corrupted within the 15 minute window between testing and that inital use!
So now I need a copy of the installation boot disk. I haven't been able to find a copy on the Windows site. Can anyone point me in the right direction? I'm not sure if the Google results I found are for the correct installation disk.
Ugh.
Ugh.
