Office Network keeps failing :(
Discussion in 'Computers' started by Mark Giles, Jan 4, 2006.
  1. Mark Giles
    Mark Giles Second Unit
    Aug 30, 2002
    272
    I have a Linksys Wireless-G w/SRX Router that keeps failing on me. I run the network wizard for all three computers on the network and hours later, I cannot access one of the computers from one or more of the other computers. I run the wizard and BAAM!! It's back to normal. Is there a reason why this would be disconnecting like this?
  2. Scott Merryfield
    Dec 16, 1998
    12,056
    925
    The router is probably locking up for some reason. Have you checked to see if you are running the latest firmware/software on the router? There may be a bug in your version.
  3. Mark Giles
    Aug 30, 2002
    272
    Ok i figured out the problem. One of the computers was losing the wireless signal, then connecting to another wireless network. This would explain internet but no network. I just removed all the other preferred wireless networks besides the one we were on. Updated firmware and moved the routers antennas around a bit. The signal is stronger, so it shouldnt be a problem anymore. Thnx Scott!
