Off-air Antenna
Discussion in 'Displays' started by James^C, Nov 24, 2005.
  1. James^C
    James^C Extra
    Sep 24, 2004
    20
    I just purchased my first HD TV (Sony Bravia 40" LCD Flat Panel). I have DirecTV with the HD TiVo reciever. Unfortunately in order to get my local chanels in HD, I need an off-air antenna. Can anyone suggest one? I would like to get an inside antenna unless they do not perform well...if that is the case, please suggest an outside version...
    Thanks again!
    James
  2. DougRuss
    DougRuss Stunt Coordinator
    Oct 3, 2001
    195
    Fill out the info at the following Link,and it will give you recommended Antennas for your Local Digital channels:
    Antennaweb
    * Zip Code is all that is need.
  3. James^C
    James^C Extra
    Sep 24, 2004
    20
    Thanks. I did the search and it said that I need a "Large Multidirectional Antenna or a Small Directional Antenna with pre-amp". Where do I get one of these? Can I pick one up at Best Buy? How much? Does anyone know any make and model numbers?
    James
  4. David Norman
    David Norman Producer
    Oct 12, 2001
    3,896
    844
    4,110
    If you mainly want the Cleveland HD stations you might be able to get away with a Silver Sensor indoors -- small cheap and easily returnable if it doesn't do the job. I think Sears may still carry those. I had decent results with the Terk HDTVa from Radio Shack though it's a little pricy for what it is.
    If that doesn't do the job then I'd suggest a Channel Master 4221 with or without a 7775 preamp though it's definately outdoor/attic material. warrenelectronics.com and solidsignal.com are excellent online sources
    The Winegard Squareshooter is smaller, less obvious, and works very well though a lot more expensive.
  5. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,333
    65
    9,110
    Mississippi
    I'm about 25 miles from my transmission towers and use the Radio Shack Double Bow Tie with good success. It sits on top of my receiver and shoots through two wall. Others have had good results with this RS antenna. To eliminate the occaisional drop-out, I'm upgrading to this antenna installed in the attic.
    -Robert
  6. David Norman
    Oct 12, 2001
    3,896
    844
    4,110
    That little RS Bowtie is an amazing little retro thing isn't it? Used the same thing in 1969 and thought it was old fashioned even then.
  7. Dick Knisely
    Dick Knisely Second Unit
    Oct 22, 2005
    372
    [​IMG] Yeah, I agree, but it worked then and still will!
