jonAB
- May 10, 2005
I have a very odd shaped room, and want to put in surround sound. Here are the limitations of the room:
1) I cannot put the speakers behind me (sofa against wall);
2) I cannot put the speakers on the side walls (one side is a window, the other is a passthrough to a kitchen.
I really need something that can be mounted on the back wall, and then adjusted to point sideways. I had been considering the Bose AM 15 or 10 systems. But I don't much care for Bose.
Are there any other quality systems with really small speakers that can be adjusted to fit the shape of my room like Bose's? I don't want to spend silly money, but anything under $1000 before installation would be something I'd consider. The priorities are small and adjustable (and good), not cheap.
PS I have an Onkyo TX-SR601.
