Roy Lumsden
Grip
- Aug 24, 2004
First off, I'd like to say that I've been lurking on the forum for over a year. I've learned so much just reading, reading and reading.
I've followed several HT build-outs and observed many more and, as a result, have decided to create my own HT. I WILL need YOUR help.
Having said that, on to my first batch of (many) questions....
The space that I'm considering for my HT is above my garage. I have room to build a 24' x 27' area but the shape is somewhat odd. At the peak the bottom of the trusses measures nine feet which slopes down to a three foot knee wall on both sides. If I decide to frame the walls so they are six foot high, the room width would be twelve feet. I would prefer to go a little wider but I am concerned about how a shorter wall will affect the accoustics. Opinions?
One neat thing about the space is that I will have access to both side via a crawl space, the top through the roof trusses, and the bottom from the garage floor (no drywall on the garage ceiling). So all cabling can be done on a "as needed" basis rather than trying to install everything - current and future - before I close up the walls.
I also like the idea of using a barrel style ceiling instead of a vaulted. Are there any benifits one over the other?
Based of a room width of 12' to 15', is there an the optimum length that the room should be?
Thanks in advance,
Roy
Thanks in advance,
Roy
