Odd little HTR5760 question (1 Viewer)
Rob*W
When I first got my HTR5760, when I was using the tuner, the tuned station would show in the display (unless my memory is really scrambled). Now, when I tune to a station, the tuned station shows briefly in the display and then it switches to show the sound field mode. Any help on how to keep the tuned station on the display? I don't see anything in the manual about this. Thanks.
Wayne Ernst
Blaine has the general concept of the issue diagnosed. On the remote for the HTR-5760, there is a display button (3rd from the bottom on the right side.) Pressing the button cycles through the options. If you press the button and a "Display Off" message appears on the readout for the receiver, the tuned station should then be displayed vs. the DSP that you have the receiver set to.
acinstallation625
