Nureality Vivid 3D Theater VHT-2000
Discussion in 'Archived Threads 2001-2004' started by NathanP, Aug 31, 2001.
  1. NathanP
    NathanP Supporting Actor
    Aug 13, 2001
    841
    Hi,
    I've been looking into these to upgrade my system..
    Anyone ever use one of these?
    I've heard if you tie it in between your pro-logic and reciever it adds a special 3-d effect...
    So my questions are:
    Has anyone here used it and does it work?
    Thanks--
    Nathan
  2. Trace Ahlers
    Trace Ahlers Stunt Coordinator
    Jun 17, 2001
    75
    Hi Nathan,
    I had this unit hooked up to my system before I went digital. Go Outlaw!!!
    It made a very big difference with the soundfield. I found myself re-watching movies just for the sound comparisons. It comes with a remote that lets you switch between the standard and enhanced sound processing.
    I still have it hooked up to my stereo system in another part of the house.
    One thing though, it's no substitute for digital. I don't know how much they're charging for the unit now,(I payed over $200.00 for it a few years ago) but the money might be better spent on a new reciever. The Outlaw 1050 is only 500 bucks.
    Good luck,
    Trace
  3. NathanP
    Aug 13, 2001
    841
    Hey Trace,
    Thanks for the info, I can get one on Ebay for $25 these days so I might try it..
    So it sounded good huh?
    Did you try it with or without Pro-Logic??
    Nathan
