Ntsc/pal
Discussion in 'Archived Threads 2001-2004' started by Jack Kelsey, Nov 19, 2002.
  1. Jack Kelsey
    Jack Kelsey Agent
    Mar 18, 2002
    49
    Will a run-of-the-mill US-bought DVD player be able to get some kind of reasonable picture from a PAL DVD that is region coded 1-6?
    There are some DVD's available in Europe that have NOT been exclusively coded ONLY for Europe - but have been basically made region-free - but I am wondering if these can be played in US at ALL without special PAL conversion in either DVD player or TV?
  2. Jeff Kleist
    Dec 4, 1999
    11,267
  3. Jeff Jacobson
    Jeff Jacobson Cinematographer
    Dec 24, 2001
    2,116
  4. Jack Kelsey
    Jack Kelsey Agent
    Mar 18, 2002
    49
    Thanks JJ!
    Does that mean the signal going from DVD drive has been converted from PAL to NTSC? The TV to be used is only NTSC - and the disks are only in PAL.
  5. Jeff Kleist
    Dec 4, 1999
    11,267
    No, the computer is just displaying what's on screen. No specific PAL-NTSC conversion
  6. Ted Todorov
    Ted Todorov Cinematographer
    Aug 17, 2000
    2,991
    30
    1,610
  7. Jack Kelsey
    Jack Kelsey Agent
    Mar 18, 2002
    49
    Thanks comments.
    I had been thinking that MAYBE there would be a DVD drive set-up that would do a PAL/NTSC conversion if one would want to go out to an NTSC TV - but have understood now that more black boxes needed for that - and mucho simoleons. And that DVD drives only put out VGA to a computer monitor.
  8. Derek.R
    Derek.R Auditioning
    Nov 20, 2002
    10
  9. Chris Xolotl
    Chris Xolotl Second Unit
    Jun 28, 2001
    482
    Budget wise a $69 Apex-1500 works fine (except for anamorphic PAL discs). If you have an NTSC TV.
  10. Jeff Kleist
    Dec 4, 1999
    11,267
    If you do an A/B comparison on the APEX's conversion and the Malata, you'll throw the apex in the trash
  11. Ted Todorov
    Aug 17, 2000
    2,991
    30
    1,610
  12. ChrisJefferys
    ChrisJefferys Stunt Coordinator
    Nov 5, 2002
    133
    Hi,
    How badly, noticably distorted would a downconverted PAL picture look? I have a Lennox 2003 player thats all region and I didn't think it would convert PAL properly, but I tried a disc anyway (Caligula R2). The picture looks good, for example the roman coin shown in the opening credits is perfectly circular. Wouldn't that be obviously distorted if the PAL wasn't being converted properly? Also the disc is supposed to be anamorphic, and it still works fine.
    Anyway, if the player is converting properly, this would be a good cheap alternative (117.00 Canadian). Of course, the overall picture quality wouldn't be as good as a JVC (you still get what you pay for!).
  13. Jeff Kleist
    Dec 4, 1999
    11,267
    From personal experience. I put the disc in my apex, looked at it, switched over to my friend's Malata he brought over. Night and day. The distortion IS annoying in a funhouse mirror way
  14. ChrisJefferys
    Nov 5, 2002
    133
    Thanks for the info, Jeff. I think I would notice that kind of distortion. I just looked at the disc again and it looks perfectly fine to my eyes.
    Its great to know, as there are a bunch of PAL discs that I've had my eye on (Hong Kong Legends, here I come!)
    [​IMG]
