NTSC - PAL projector settings (2 Viewers)
Carl Hood
Grip
Hi,
I've just purchased a new Sony VW11HT projector. After reading several articles on tweaking the settings for maximum performance for both NTSC and PAL signals, I was wondering if it is possible to save the ideal settings for both permanently. Can I set it up somehow to toggle between, say, custom 1 and custom 2 without the need to re-calibrate contrast/brightness each time?
Cheers,
Carl.
Will*M
Grip
Carl:
I think you should be able to. I know with my multi-region capable projector I can set memorized modes. Check your manual and see if you can do something similar.
NHCondon
