noticed something odd earlier.
Discussion in 'Archived Threads 2001-2004' started by paul e., Jul 14, 2002.
  1. paul e.
    paul e. Agent
    Jun 12, 2002
    49
    i was going back and doing my weekly avia adjustments and i noticed on the overscan pattern my screen is off to the left to much. i found a way to adjust the screen up and down but not left and right. does anyone know how i can adjust the screen horizontally?
  2. John-Miles
    John-Miles Screenwriter
    Nov 29, 2001
    1,210
    weekly adjustments?
    please excuse me for saying this but isn't that slightly um excessive?
    I know i would hate to think that any tv would need or even benefit from weekly adjustments.....
    as to your question sorry i dont know.
  3. Juan_R
    Juan_R Supporting Actor
    Sep 4, 2001
    683
    It would probably help if you told us who the manufacturer of your set is.
  4. paul e.
    paul e. Agent
    Jun 12, 2002
    49
    sorry 'bout that it's a sony kp57hw40, and as for weekly adj. i really don't adjust much i just check some of the patterns (t.v. is'nt quite 60 hours old).
  5. John-Miles
    Nov 29, 2001
    1,210
    ah makes sense Paul
  6. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    You might want to check other sources.
    Try watching one of those news shows with 2 talking heads side by side in 4/3 windows with the set in full or widezoom. If the distance between the outer edges of the windows and the outer edges of the screen are equal on both sides, the problem is not with the tv.
    What I'm trying to say is that an off-center image is not always the fault of the tv. Sometimes the dvd player will offset the image to one side. Panny RP91s had this characteristic when first released. Since you can play AVIA only on a dvd player, it's impossible to tell if the problem is in the tv or the player unless you find some other display source to judge centering.
    My KP-57HW40 has the picture offset to the left a bit on dvd from my JVC player, but on other sources like regular cable or satellite, the picture is perfectly centered.
