Not so technical SVS question
Discussion in 'Archived Threads 2001-2004' started by Willem Vos, Jan 23, 2003.
  1. Willem Vos
    Willem Vos Stunt Coordinator
    Nov 14, 2000
    227
    Hi, this is not about sub placing, crossovers or anything like that... this is a question about the SVS fabric.
    I was crawling around the sub (don't ask) and noticed that on the back (just under the amp section) there is a little piece of thread showing (probably at the end of the sewing).
    I'm really urged to just take the scissors and cut it away, but the last time I did that with a sweater it started getting worse (it started to come loose)... any advice?
    (a bit of a silly question, but there you go [​IMG] )
  2. Willem Vos
    Nov 14, 2000
    227
    Nobody had this with his SVS?
  3. Tim Morton
    Tim Morton Stunt Coordinator
    May 5, 2000
    212
    I think the right thing to do would be to leave it alone...i can see nothing good come from cutting it.
  4. Brian McHale
    Brian McHale Supporting Actor
    Dec 5, 1999
    514
    12
    Brian McHale
    You might want to e-mail them directly. They seem to be very good about responding to direct queries.
  5. SVS-Ron
    SVS-Ron Screenwriter
    Jun 2, 2001
    1,074
    Willem,
    You have mail.
    Ron
  6. EricN
    EricN Stunt Coordinator
    May 30, 2000
    71
    10
    Willem, here in the US every mattress has a DO NOT REMOVE UNDER PENALTY OF LAW tag. That string MAY serve the same purpose. I would leave it alone and not get into trouble [​IMG]
