Not done, but running, want to see?
Discussion in 'Home Theater Projects' started by Rich Kraus, Mar 1, 2005.
  1. Rich Kraus
    Rich Kraus Stunt Coordinator
    May 3, 2000
    209
    here's some pictures of what ive been working on for the last forty forevers:
    http://www.richkraus.com/ht/
    lots to do yet, but its at a nice "it's working" point right now (and i finally got the content loaded), so i thought i'd share.
  2. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Rich,
    Looking like a nice little place to hang out.
    Hopefully you can sit down and enjoy a movie soon.
    chad
  3. Bryce_H
    Bryce_H Stunt Coordinator
    Oct 20, 2004
    116
    10
    Rich,
    Looks good. I am in the process of finishing my basement into a dedicated HT. I plan on putting fabric on the walls as well. What are you using for fabric? Where did you get it? Are you going to put a carpet pad behind the fabric on the walls?
    Good luck with things.
  4. Rich Kraus
    May 3, 2000
    209
    there will be a layer of some (basically fiberglass duct board) material under parts, and some other (basically polyfill batting) material under others.
    havent settled on a source for the fabric.
  5. Colton
    Colton Supporting Actor
    Jan 12, 2004
    795
    What size is your screen? How far back is your projector?
    - Colton
  6. Rich Kraus
    May 3, 2000
    209
    actual screen is 99 inches, im curently zoomed down to a 95ish immage.
    the projector is about 13.5' lense to screen.
  7. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Looks good, nice work in progress and congrats on the new home.
